Here is what I get on the 3525 amp produces no rail or regulated voltages
Pin 1:1.75
Pin 2:1.85
Pin 3:0.00
Pin 4:0.68
Pin 5:2.05
Pin 6:3.76
Pin 7:1.93
Pin 8:4.93
Pin 9:1.40
Pin 10:0.00
Pin 11:1.14
Pin 12:0.00
Pin 13:13.86
Pin 14:1.13
Pin 15:13.86
Pin 16:5.20
Pin 1:1.75
Pin 2:1.85
Pin 3:0.00
Pin 4:0.68
Pin 5:2.05
Pin 6:3.76
Pin 7:1.93
Pin 8:4.93
Pin 9:1.40
Pin 10:0.00
Pin 11:1.14
Pin 12:0.00
Pin 13:13.86
Pin 14:1.13
Pin 15:13.86
Pin 16:5.20
PapaZBill handles the Kicker posts.
Measure the DC voltage with the black probe on one of the non-bridging speaker terminals.
Ok I have rail and regulated voltages using the non bridging speaker terminal .
Problem I’m having is the map has no output
The amp has no module with it .
As soon as I jump the connections on the board as seen in post 2 the amp has 2 volts measured directly across the speaker terminals on both channels .
And the amp has no output
Leave the wires jumped as was suggested to you in post #2.
Here's a link to my ZR360 repair, I repaired it and got audio. Papazbill had some test checks you can try whilst troubleshooting.
Right now I have audio but a terrible dc at the speaker terminals when initially powered up. The amplifier is passing the checks suggested, I've ordered a few parts to replace for the current source and differential pairs to try to get the DC out.
Kicker zr360
Kicker zr360
- General Interest
- Car Audio
- Kicker ZR360
