Krell Showcase Processor/Pre Amp - turns out, clicking noise from power - relay?
Hello
I have a Krell Showcase Processor I use as a preamp.
It is not turning on (goes back to standby) and if it does turn on it either plays for a bit and turns off or it makes an off clicking noise. Someone thought this may be the protection circuit thing, relays clicking, is that likely?
Anyone know a good electrician in West London, UK?
Best wishes Edward
Linn LP12, Naim NAT02, Revox PR99, Meridian 557, Sonus Faber Domus Grand piano floorstander, Primare D20
Thank you Duncan I will reach out to them, good tip! Its not that close but is the right side of London at least in High Wycombe!
I think Absolute Sounds will be too ££, its only £600 for the machine now.
Best regards Edward
