Parameters:
Ingangsspanningsbereik: DC +/- Dual Voltage +/- 12V - +/- 55V
Vermogen: 120W / 8R +/- 50V spanning
200W / 4R +/- 50V spanning
THD: <0,0005% 1KHz 10W
SR: 35V/US
Dempingsfactor: > 200, 8ohm belasting
Ingangsgevoeligheid: 1,6 V Output 120W 8R
Frequentiebereik: 15Hz - 50KHz (-3DB)
Spanningsvergroting: 31 keer
PCB-grootte: 144mm * 45mm
SR: 35V/US
wired like this?Yes! 2 amplifiers driven via ballanced input works well when wired correctly. This doubles the output power as well. It also cancels distortion by a factor of 5 to 10.
How to cennect the in/out grounds?
Within the amplifier the grounds are connected (VOED). The ground of the XSLR CAN be connected but is not required as the output of each half is regulated against the connected grounds. I have inserted ground lift in the XLR ground as well as one of the Cinch connecters. when the unit is in use as stereo amp you need to connect al least ine of the grounds of the cable.
