http://www.ing.iac.es/Astronomy/observing/manuals/ps/tech_notes/tn107.pdf
http://www.diyaudio.com/forums/showthread.php?s=&threadid=19798&perpage=10&highlight=&pagenumber=1
For audio is it worth the effort of compensating a particular LED for temperature ?
http://www.rapidonline.com/netalogue/specs/56-0300e.pdf
Should I look for the steepest curve IV LED ?
by steep do you mean less voltage change for a wide range of operating current?
If you are looking for a voltage reference then you want little change in voltage, provided the temperature coefficient does not get significantly worse.
ash_dac said:Should I look for the steepest curve IV LED ?
Use Red LED for temp. compensation; mind the voltage drop at choosen standing current; 10mA (at least) may be required; ''steepest slope'' curve is a ''good thing''.
Only in input diff. stage in power amps.
In Doug Self's discrete preamp article, I read that the tempco of a LED is very close to that of a BJT. To check this, I rigged up a test circuit comprising a transistor ccs, biased with a red LED. I monitored the current with my meter whilst heating the assembly with a hairdryer. If both the transistor and LED were heated equally, there was little change in current. If either was heated more than the other, the change was significant. This experiment was crude, but it showed that an LED biased ccs is good enough for me.
An old amplifier I have uses the 'ANF current source' in the differential and VAS. Would a LED current source be better in this situation ?
Isn't the function of the diode (Red or Green LED or just 1N4148) in the CCS to provide a voltage drop with which to bias a transistor? If that's the case, isn't the issure the stability of the voltage drop rather than the current?
I seem to recall from an experience trying to get a CCS / LTP to do what I wanted, where I was scrathing my head and making the repeated measurement to try to fathom things, hat the only thing measurement that always came out the same was the thedrop across a red LED. Hot, cold or luke warm. However, if you swapped out for a different PN from as different mfg -- then you would get a change.
yeah we want a steady vdrop to have stable i in ccs
thank you guys for your valueable inputs
john
john
- LED CCS questions...
