I made this preamp and with higher gains it is oscillating, you can hear 10kHz hiss. When I remove 100 nF pointed capacitor the hiss is gone and sound is crisp. There is 100 uF filtering. I am using guitar as the input. But still I wonder, maybe I should put 1 uF instead 100n and add 500 pF feedback capacitor in parallel with 100 kOhm resistor to remove hiss on higher gain?
- Analog Line Level
- Line-in preamp with opamp
