List of tubes with same pinout as 6V6, 5881, 6W6, etc?
Hellois.
Anyone have a list of beam tetrodes and pentodes with same pin-out as 6V6 etc? I want to try all different types but only the types fitting into the same socket. EL34 and the like as well (where screen must be connected to cathode externally).
Does that tube base with that pin out have a nomenclature? I can search myself if I know that name.
(I know they have different electrical characteristics, and that is the point.)
Hellois.
The base of these is type 7AC, as can be seen under the pin diagrams on tube data sheets.
https://tubedata.edebris.com
A search for 7AC bases on a different tube data site: http://www.nj7p.org/Tubes/SQL/Tube_query.php?base=7AC
There may be other tubes that are mostly the same and will drop in with some minor changes like the EL34, which you mentioned.
Another such tube is the 6N6G which I use in PP in a Magnavox console amp that originally used 6V6s and in a SE amp that I built recently. Since it's internally biased, when using it you just eliminate the cathode resistor and connect the pin directly to ground.
Here's my list: NOTE- some require a top cap instead of pin 3 for plate but that's not very hard to rig (8GT)
12A6 12EF6 12EN6 12L6 12V6 12W6 1614 1621 1622 1631 1632 17L6 17W6 25A6 25B6 25C6 25L6 25W6 26E6 26L6 35L6 36L6 50C6 50L6 50L7 5824 5871 5881 5932 5992 5V6 6046 6550 6AG6 6AY5 6DG6 6EF6 6EY6 6EZ5 6F6 6G6 6K6 6L6 6P6S 6P3S 6U6 6V6 6W6 6Y6 7184 7408 7581 7EY6 8417 9EF6 EL33 EL35 EL37 KT32 KT61 KT63 KT66 KT67 KT71 KT76 KT77 KT88 KT120 KT150 PL33
8GT BASE: 25E5 25GF6 30P19 30P4 6CM5 6P31S EL36 PL36 TT21 TT22
6CA7 is a Beam Power tube.
EL34 is a Pentode.
They both have the Beam Formers / Suppressor Grid, respectively, connected to Pin # 1.
Connect Pin # 1 to Pin # 8.
You will not find a more closely matched set of specifications/characteristics than the 6CA7 versus the EL34.
Plug and Play tube rolling.
Not the often Plug and Pray tube rolling game that some people try with vastly different tube characteristics.
SemperFi,
If you want to tube roll the 6CA7 and the EL34, I forgot the 3rd tube in that series:
The KT77 already has the Beam Formers tied to the Cathode, at pin # 8.
And you already tied Pin # 1 to Pin # 2 for the 6CA7 and EL34.
The KT77 specifications/characteristics are also extremely close to the 6CA7 and EL34.
That gives you the Trifecta opportunity for tube rolling.
Plug and Play.
Cathode bias will make this the easiest plug and play, because nothing has to be re-adjusted.
Former USNR USS Braine, DD630
