Hi there, I have a slightly modified Lite Audio DAC60 with non-working digital selectors. While poking around in the DAC I have probably connected the display ribbon cable the wrong way (or something) and sent some voltages astray.
The display is mounted on a separate assembly with momentary switches and a HEF 4094BP register chip. The assembly is hooked up through a ribbon cable to 4 transistors on the main board, leading to an AT89C51 microcontroller. All the microcontroller does is control a switching relay for Coax/Toslink and it displays sampling frequency (which still works).
I am not really comfortable with the microcontroller stuff so any help with troubleshooting is welcome. Of course, it doesn't help that I can't find a good schematic. There is a rough one here (AT89C51, big chip in the middle):
Lite Audio Dac 60 Schematic
And the digital input circuitry (minus the microcontroller) can be found here:
http://www.audiodesignguide.com/DAC/dac_ah_circuit_new.JPG
1. I have measured the voltages on the transistors and they all measure the same (ok?)
2. Tried substituting an exact replacement for the HEF4094BP.
3. Any chance I could have fried something on the microcontroller?
Just to add, if there is any Lite DAC owners here feel free to send me a PM. Would be very interested in discussing possible mods.
PCM63 DAC mods
DAC60 is the same as older DAC50 (DAC chip is different, PCM1704 instead of PCM63).
