LM393 Differences
I need to replace a surface mount ic in my amp and the markings are LM393 which the data sheet says it’s a dual differential comparator.
now it seems like there are a ton of difference ones LM393, LM393DR, LM393D, LM393P, LM393N……etc the ic just says a LM393 Is there any difference?
Cheers
Thankyou so much for your super quick replies!!😀 this is the chip U13 if that’s any help?
I'm assuming it's the same as the U24 chip up top???
rm1pPhs
[/url][/IMG]
Cheers
I designed a USB based LC meter and used a LM393 for the oscillator.
I found some versions worked better than others. There are numerous manufacturers of this device.
Some had glitches on the edges which really messed up measuring the frequency using a microcontroller. I tried changing hysteresis and "speed up" cap but that didnt fix it.
Wow the more I look the more that I find.
So many different suffix with slightly different specifications. I researched the suffix and I get various answers.
I still can’t find a straight LM393 like in the photo I pasted on the screenshot
(That’s the original that’s faulty) The screenshot is like only half of the ones I have access too haha
@abraxalito should I pick the LM393D like you said?
Cheers
[/url][/IMG]
