Low to high impedance cable
You want to connect microphone and DSLR to an amplifier (say, to add voiceover or live comments to a video) or connect the mic to the DSLR to have better audio when filming?
If so, doesn't your camera have some microphone input?
What microphone will you use?
What camera is it?
EDIT: where are you?
In any case, it's more complex than "just a cable"
Get a microphone that is compatible with the DSLR, that would be the best bet, or put the audio out of the DSLR and the MIC into a mixer...
The sound out of most DSLR's in built microphones is often terrible, with the noise of the camera often overpowering and external sounds and the often heavy breathing in the background of the camera user....
The cable does not change the impedance.
The copper in the cable just connects the two output terminals of the mic to the two input terminals of the receiver.
You need to "change" the impedance using a transformer, or with an active circuit (like an amplifier or buffer), if the current input impedance of your receiver does not suit the mic output.
I read the full spec brochure Canon U.S.A. : Consumer & Home Office : EOS 70D and nowhere it mentions external microphone connectors, even less type or sensitivity.
So please first google and post here relevant info, otherwise answering is impossible.
Now to the camera use:
a couple weeks ago I watched the French film "Tomboy".
Tomboy (2011) Movie Trailer HD - YouTube
I was amazed at the high quality image (I already knew it was a very low budget movie) ... filmed with a Canon DSLR almost the same as yours, Canon EOS 7D .
You can read how it was used in:
One Thousand Lux: Film review. An analysis of the Cinematography of Tomboy by Céline Sciamma
at the same time I was appalled at the horrible sound, so much so that I couldn't stand the torture and by the middle of the film I had to leave my seat and wait outside for my friends, go figure.
The BIG (unbearable for me) mistake was that apparently, on many scenes, when filming at a certain distance (say, beyond 4 or 5 meters away) and/or in a relatively noisy environment (the budget allowed no studio use, most scenes were filmed outdoors or in "real" homes, etc.), obviously the on camera mic was not enough, so they added some external mic close to the actors.
So far apparently so good, but using 2 microphones to record the same person, at about the same level but separated by such distance, creates a comb filter
which is both strong, annoying and impossible to equalize, because it's caused by phase differences.
Q. What exactly is comb filtering?
Many dialogues sound exactly as if they had a flanger applied (think Van Halen guitar sound) .
They should have used an external microphone (or more, if very carefully placed and mixed) and mute the internal one.
Or record audio separately, even on a cheap Zoom digital recorder and later join audio and video.
Pity that a poor audio decision (hey! we have 2 mikes !! let's use them!!) took much value away from a film which was visually very well made.
Oh well.
Back to your problem: I suggest you do NOT use the internal microphone at all, for a multitude of reasons (including the heavy breathing mentioned above) nor even "a cable" but you get a cheap mixer such as:
http://www.amazon.com/Behringer-502-XENYX502-5-Channel-Mixer/dp/B000J5UEGQ/ref=pd_cp_MI_2
Only U$43 and free shipping .
I occasionally shoot 'home' video with my DSLR and I do mean home, the pictures are excellent the audio with the on camera mike is terrible. Most that do shoot video a lot get some external audio recording or interface as mentioned above, most DSLR do not have great audio even with an external mic.
7d have external mic input so please JMFahey don't google look at 7D 🙂. microphone impedanse 600ohma have good sound not best but it is ok. If you have eng transmiter and resiver with ➕4db you only have to attenute line level to -40db to have good sound
