LTP input stage questions
Hello good people.
I've been experimenting with my Yamaha AX-400 to learn about power amp theory and did an experiment that came out with unexpected results, or at least i thought they were unexpected.
I removed C133 (LTP input bootstrap) and made new measurements after and frequency response was extended in the bass without the capacitor. Shouldn't happen the other way around?
C129 input cap was previously changed from 10uf electrolytic to 3,3uf film. Both measurements feature the 3,3uf film, just for consideration.
All other parameters, THD, noise and IMD stayed exactly the same.
thank you all.
The pole created by C133 and R147 is at a relatively high frequency, 16Hz, much higher than the input pole, so the purpose of the bootstrap is probably to raise the input impedance for the audible spectrum, not the subsonic frequencies.
Why did Yamaha chose it to be that way is open to speculation, perhaps having the poles too close of one another caused unwanted VLF peaking?....
Yup. Tl1 and tl2 connections to tone board removed, tl1 and tl2 shorted, r159 removed, r155 changed to 49kohm. Before freq. Response was a skewed mess.
I thought bootstrapping the input, therefore increasing input impedance would extend bass freq. response but clearly the bootstrap capacitor is too small, it seems. On higher models on the Yamaha ax range they use larger caps here, like 16uf.
Have not looked at the circuit but cannot see any loading issues when a large value pot precedes a low input impedance stage. The log characteristic of the pot will be skewed to a degree but this is just an operational inconvenience. Perhaps they used such a large value pot + bootstrapping in an attempt to keep the overall input impedance high. To what end is another question.
where is that taking us to?
/OtDXEkOv-_dAfya5uI0bJCStrRlymZ1x7lvDhUBVvAsf_VZVam1TfAnlghRd705S_mKAW4Ag0sgDQ7jo-B_CwU-fgVSC3BKQQ_WJEJOw5yXNoyWFBlVXoJSNBVG6we_dSgWq5EYBMCMMTKzR7D5s_VK9GSlVnhh9yUJ-NiqwbP00WdVb58IAStTkpjL0f2sNFdygOMDvufiQ7n8aOsaagnE5NBZdqJUuD2bp2xU3fvouy4bbb4ekiibhRZEj3LQ8Vw9TwEFvlwPnp7hhw6yju5sYZn8XgpRATfrQHvSpJ19SZPgf2R8P7PJXq4ChH-wABEZc3hKBa0zByGCydOpH_7ZAMdBIZSBe2OydEyWmkSdsNyZxXmqAs7AqxBHvnV4MBofXUzLZLCK_On8j0Mftw3KYLlQXdDHIwmeanr80aMGBRevGd4ZuQ4TGsN_rKDVkyaFrOMOiIqeMhSJILcVNdtBt5ZLmjS2DfZf-pr1uxOTjEMdxU81RUIRzgIwt1H4sz2Vdvx3jZZc912kAR7iVH8N78ad0XrPtLcRE7IfWAWfNCErpPUjJN1uMoARXt2WNvZKfHEOrhVupiKpiTXCWKV9Xv6QcTDMjd5XgTmE=w1305-h835-no
Attach your pic so that we all get to see it.
How to attach images to your posts.
I'm sorry.
I thought hot linking images from google photos would work as i can see them perfectly... weird. I can see them perfectly embedded in my posts on my phone also...
I'm not really wanting to remove the cap or something like that, just trying to understand it's usage and implication on noise floor, dynamics/loading, stability, or if only for filtering subsonic frequencies.
My guess is that it must have something to do with the 60kohm passive volume.
I attached the image.
I find linked images especially annoying when going through older threads. Many old linked pictures are gone, and with them a lot of information. Those threads in more than one case became almost useless...and this is a pity.
Completely agree. Will always attach from now on.
Best solution would be to replace that 10uF electrolytic with a film cap of the same value:
a Wima polyester cap (MKS2B051001N00JO00) will probably fit nicely.
Thank you for the suggestion but that i'm well aware of that kind of possible improvement procedure. I already have two big nice orange philips 4.7uf polyesters in there. 2.7hz corner frequency without the bootstrap, around 10hz corner frequency with 1uf bootstrap, and 0.4hz (or something likethat) with 47uf bootstrap like the Yamaha AX-500 (this one is the 400). Nice improvement in various sound qualities comparing to the old 10uf ELcap.
Anyway, the question was just trying to understand yamaha decisions on this model. AX-500 has 47uf bootstrap and is a very similar amp, almost the same circuit and topology. The top of the range AX-900 has active preamp (buffer after vol. pot and all that) and no bootstrap.
thank you all
ps: attached the current state of the amp
