Ltspice Vs measured response
LTspice is giving me a -3dB of over 1MHz
all models are b.cordel and Ian Hegglun (i get the same results with other models)
with the real circuit, i measured a -3dB of around 500KHz
my 2N5xxxx are coded "B331" so i replaced these with bc559c/bc549c with the same results
mje340g/350g were replaced with old bd139/140 with the same results
(outputs are from profusion)
any ideas why the circuit -3dB is so off compared to the LTspice?
  • sim.asc
    sim.asc
While I like LTSPICE a lot it does have its limitations.
I did a valve circuit running off 12V B+ and it simulated great.
In practice it failed to work. I have to add positive bias to grid to get it to work on the pcb.
You can also feed an amplifier stage in SPICE with an input signal that causes the output to go above the supply rails, and the output merrily puts out a clean signal exceeding the rail voltages
Hi ctrlx,
Nice circuit!
On a real pcb its not only parasitic capacitance youre getting.
Try simulating power supply impedance. Add some resistance and inductance to your tracks. If your amp is high bandwidth PSU impedance could have a big impact I found in my ltspice vs prototyping experience.
Also try adding some ESR and inductance in your feedback electrolithic. Try bypassing it on pcb with a ceramic. Also bypass psu with capacitors that have low impedance at high frequencies.
Ruben
