Markaudio Alpair 10 Bass Wide Drivers
Hello,
I have 2 pairs of Alpair 10 Bass Wide drivers for sales. They are grey color cones. The special price is USD58/pair + shipping cost.
The Alpair 10 bass-wide driver. It's all about the bass with this driver. We set out to make this unit to deliver a solid, rich and most of all, a detailed sound without the need to operate at high volumes. The compliance of this driver suits listeners who genuinely love music and require real detail, not simply a low range thump. This is not a rock and roll driver, there's plenty of those already available.
The Alpair 10 is ideal for audiophile uses, multi-media and multi-channel applications.
Features:
■Rich low detailed bass without the need to be driven hard.
■100 mm ultra low mass thin-wall mixed alloy cone with multi-coating.
■Ultra wide frequency range (35Hz to 10kHz).
■Wide excursion (9mm one way).
Specifications:
■Imp-nominal: 6 ohm
■Revc: 5.4 ohm
■Fo: 35.0Hz
■Sd: 8.99mM/N
■Vas: 21.0Ltr
■Cms: 1.84mM/N
■Mmd: 10.73g
■Mms: 11.22g
■BL: 6.25T.M
■Qms: 2.37
■Qes: 0.35
■Qts: 0.30
■Levc: 88.73µH
■No: 0.25%
■SPLo: 86.2d
■Xmax(1way): 9mm
■Power: 35watts cont., 70watts max
Alpair 10 Bass Wide Installation Guide:
http://lautsprechershop.de/pdf/markaudio/alpair10woofer.pdf
