MC Preamp vs Step Up Transformer
There are three solutions for amplifying MC signal to line level:
1. High gain (~60dB) RIAA preamp
2. Step Up Transformer + MM input RIAA preamp
3. Same as point 2 but using electronic 20dB gain block instead of SUT
From your experience, how do you value each solution judging by final (audible) result?
Can solution 3 keep up with solution 1?
Reactions: hbtaudio
2 - depends on the transformer - some little ones slur - soften transients - 40 some years ago I had a Technics SUT with multiple shielding and 200KHz bandwidth - SOTA. Also, a microphonic miniature tube pre-preamp. What does ASR say regarding practical gain devices for MC cartridges ? -that would be an interesting place to post these questions.
Reactions: hbtaudio
HI,
I think the question is too generic as each MC cart behave a bit different and may need different solution to sound best comparing another MC. For example a Denon DL 103 it is said that sound best with a step up, but a Pre with the correct gain ( not only 60 Db but 65 or 67 Db is needed ) in my opinion may sound very good and may avoid other hum problem of the step up.
Other MC may sound only with the step up and other MC very well with a pre.
Rgds
Adelmo
Particular case is if a DIYer has an MM phono preamp and is very pleased with it but needs a solution for his/her new MC cartridge. Which approach is most likely (least risky) to give equally great result? Build #1, buy #2 (SUT is not easy to DIY) or build #3?
This is what I've stumbled upon on a web site of a high class SUT manufacturer:
Why You Should Have a Transformer – And Why They Are Rarely Seen​
The purpose of MCX is not simply to allow moving-coil cartridges to be used with moving-magnet phonostages (most valve designs, for example), but to allow high-output moving-coil cartridges the chance to realize their full potential. Transformers have much more benign distortion characteristics than active circuits and are capable of producing a sublime soundstage with detail and separation unsurpassed by the more common transistor and op-amp alternatives. The reason transformers are so rarely seen nowadays is because they are incredibly expensive compared to transistors and chips. A complete moving-coil phonostage is obviously more convenient than a separate transformer and moving-magnet phonostage, and a moving-coil phonostage made entirely with solid-state circuitry is considerably cheaper to produce than one with transformers.
Makes sense?
The least risky is to listen in your set up before to build or to buy it. Or based in your equipment, cart, pre phono , amp, speakers and soo on ask suggestion to whom has tested something similar or have experience.
Rgds
Adelmo
How about an transimpedance/current mode head-amp which plugs into your existing MM-stage? Often low-output MCs have plenty current, so better s/n ratio. There are some great designs on site, for sure. Higher output will do fine in several different configurations, so I agree, it depends a bit on the cart.
Dagfinn
Reactions: dennis h
