Hi.
I'm building my 4th ghettoblaster. What I've learned so far is that stereo setup is no use outdoors. I've also learned lead acid batteries (or whatever they are called) are no go, way too heavy.
I don't know that much about speaker designing so I prefer to buy 2nd hand passive speakers and use them as a basis. Someone with better skills has designed them soundwise. I'm more into designing the looks of the device!
4th ghettoblaster aka Megablaster2010:
8,75" bass / 1" tweeter from Behringer Truth 2031p speaker built into new box of same volume and same tuning frequency. Should give 89db/w from 55hz to 20000hz.
Sure electronics 2x100w tripath TK2050 amplifier. I'll use only one channel and convert the signal to mono before amplifier.
2x 7,4V (=14,8v) 4000mAh Rc car nimh batteris. They have the best ratio of weight/price/easy to use for me. Amplifier can take voltages up to 36V so if I need more power I'll just throw in more batteries.
Finished blaster looks like a stereo device. Other channel is only fake speaker grilles. I'll place reflex port behind the fake bass driver.
Here's some previous audio projects I've done so you know what to expect:
I think your primary problem is way too ineffective speakers. 89 dB/W/m for outside use is like paddling upstream with a toothpick, no matter how strong you are (the powerful the amp is) you'll get nowhere.
Since you already are aiming at 9" speakers why not go the extra inch, and get high sensitivity 10" PA speakers that can be had for a reasonable money.
I also wholeheartedly recommend a bipolar design as my own has (see sig).
Hm my first model had stereo setup with 89db/w speakers. It was loud enough for my use with 2x25w amp but cut off freq was a bit too high. This design is same in size but should go lower. I like I can choose in which direction the sound goes, thats why I don't consider bipolar.
9" is absolute maximum for the size of the bass driver. You can still recommend me 8" drivers which are more efficient than what I have now but would play below 100hz. I prefer lower notes than more spl. Crossover design is still a problem for me.
Thanks for any ideas!
Well, your 89 dB/W/m speakers needs about 100 Watts to play as loud as the speakers I use plays on 10 Watts! And those are not even really high sensitivity speakers at 96 dB/W/m (since I only 2 of them totalling 99 dB/W/m).
You looking at the problem the wrong way. You are never going to get useful really low bass output in an outside enviroment in any portable package.
For example, you could have speakers like mine and make a box 4.2 times larger and get a 55 Hz cut-off but it wouldn't help much since you'd still need an amp capable of output 10 times power than the amp6, or about 200 watts, to equal out the bass loss. And so you're back on miniscule battery life times.
Settle for a cut-off at no lower than 80 Hz and you have a practically possible goal.
Ok, my limits are: 8" driver in 25l enclosure and 14V 4Ah battery. What drivers and crossover do you recommend? I made a quick search but found hundreds of drivers which might work. Too much to choose from ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I still try the Behringer in it's original box outdoors, maybe I'll be disappointed.
With my low experience this drivers specifications look great: http://www.hifitalo.com/elementit/eighteensound/580011.pdf
Eighteen Sound 8NMB420 with average sensitivity of 95db. Specs sheet recommends a 20liter box tuned to 60hz. What would be a matching high frequency driver? What kind of crossover should I use?
And here is Precision Devices PDN.8BM31 http://www.precision-devices.com/asps/uploads/super/75.pdf
Specs look pretty similar to me, Precision deviced being the cheaper choice under 100 euros.
I'd probably chose the Precision Device woofer because of price and that you can order them in 4, 8, and 16 Ohms versions. So you can get the 4 Ohms one. You'll not get output lower than about 80 Hz with either of them though.
Second problem is that you'll use a 14.4V battery, so unless you have a dc-dc converter you amp will output maximum 20 Watts RMS per channel into 4 Ohms, regardless of the specs of the amp. You can always throw in more batteries of course but just remember that power consumption rises as well.
Look at it this way, your battery pack has 57.6 Wh battery life. That's about the same as a standard laptop battery but you'll be drawing about 14.4 Watts at maximum volume (divide product of max RMS total for all channels by 4) so you'll effectively only have about 4 hours of battery life time at that voltage.
All these things are explained in my Boominator thread though, either directly or between the lines somewhere.
Thanks for yout input again. My plan has place for four batteries =28,8V so I can choose between more spl or less weight. I have no need for full day operation, atleast at maximum volume.
This is again said my 4th build so I know pretty good what I need. Extra spl is never a minus so I consider that 8" Precision as a lf driver as it's also light weighted. I quess I can find a matching tweeter from normal tweeter. To match the 95db/w. I take recommendations of tweeter in consideration.
Are ready made crossovers ok? I can get cheap assembled 12db/okt crossovers for atleast 2000, 2500, 3000hz.
25 liter tuned to 80hz sounds okay. (My miniature blaster has a 3" fullrange tuned to around 110hz and it's really nice when listened in couple of meters radius)
I wouldn't go with a ready-made filter. Filters must be optimized for the drivers used. For example if you buy a ready-made filter those will most likely be for 8 Ohms speakers and not 4 Ohms speakers as I recommend, you must use needs a completely different filter for 4 Ohms speakers.
As for tweeter, I recommend the P.Audio PHT407, not the N version as metal diaphrams are quite annoying for outside use as they change sound according to temperature. Bang a 3.8 Ohm power resistor across the terminals and you have a 4 Ohm tweeter with 95 dB/W/m sensitivity to match the woofers perfectly.
A 6/12 db filter should work out fine with a little tweaking.
Thanks!
Im getting the precision bass from thomann, unfortunately couldn't find that p.audio tweeter there. Would any of the tweeters on the link be acceptable pair for Precision Devices PDN.8BM31? Small size is preferred so I can easily hide it behind a speaker fabric.
Speaker Components for High-Frequency Range - U.K. International Cyberstore
No, none of them would be a good match IMO.
Get the PHT407 at Lautsprecher Intertechnik - Das Unternehmen - Lautsprecher für Selbstbau, Hifi, Pro Audio & Car Hifi
I found crossover design calculators, now I need to choose the crossover frequency. What do you recommend?
Precision Devices PDN.8BM31 AND P.Audio PHT407, would 3000hz 12db/okt be okay?
Yeah, about that. Normally you'd chose x-over at about twice Fs, so 3KHz. In my Boominator mark II, I'm not pressing them very hard so even lower is ok (I use 2400 Hz).
Does this look okay crossover for ghettoblaster use? Is 5db okay dampening for tweeter? Btw. that http://www.intertechnik.de/ seemed pretty dead. I asked about postage cost for the tweeter via e-mail and got no answer.
http://www.p-audio.co.uk/products/db_product_3_23_pht-407.htm
Look at the response graphs.
The woofer has a relatively flat response with 92 dB average sensitivity up to about 800 Hz where it rises dramatically with 3 dB. So your baseline sensitivity is 92 dB.
The tweeter has a slowly rising sensitivity down to 2KHz where it peaks with 101 dB. But is rather linear at 98 dB average from 3 Khz to about 13Khz (remember here that mp3s which is likely your most common source don't have information above 13KHz anyways).
With these points in mind you absolutely can't use a standard filter since you need the filter to cut both these peaks and still filter accurately. Now you can do that the easy way by adding bandstop filters, or the hard way by making educated guesses, and good old trial and error.
My starting point would be Butterworth filters since they are easier in the sense that you know the response is down 3 dB at the x-over frequency.
For the woofer I'd go with a 6 dB per octave filter at 1.5Khz because that will dampen the peak, and since we're not linearizing the impedance the filter effectiveness is dampened with rising frequency because of the rising impedance.
For the tweeter I'd go with a 12 dB per octave filter at 3KHz because that will dampen the tweeters peak and since again filter effeciency is decreased by rising impedance the actual x-over frequency should be around 2.5Khz.
Remember to attunate (dampen) the tweeter by 6 dB. Also please note that this will be a in-phase filter so you should not invert the tweeter.
Now I'd listen to it (and measure the response if you can) and slowly unwind the woofer filter coil until everything falls into to place but I'm pretty certain it won't require much tweaking as it's very similar to what I've done on the mark II version of my Boominator.
I hope I understood all correctly. Are the drivers now in correct phase? I wasn't able to choose Butterworth for 6db slope, is this important. 6db slope calculator didn't have option for that.
To keep us entertained: (maybe add some hello kitty logos
L-R and Butterworth are basically the same with 1st order filters, so yeah ... that's exactly what I would do.
Another alternative would be an L-pad that converts the impedance to 4 Ohms and change the tweeter filter to a 4 Ohms filter to avoid phase change at the x-over which would result in (if I recall correctly, others may correct me) 1.17 Ohm serial and 4.38 Ohms parallel.
I must have had a bad-brain day yesterday.
To impedance correct with an L-pad you just parallel the tweeter with a 8 Ohm resitor between the L-pad and the tweeter. Now the L-pad will be Rs=2 and Rp=4 Ohms respectively.
Now since have 2 parallel resistors and we know the total impedance should be 2 Ohms for those 2 resistors and the tweeter itself, we can just reduce the 2 parallel resistors to one of 2.6667 Ohms.
To recap, to get the filter to see 4 Ohms impedance and have 6 dB dampening, Rs=2 and Rp=2.6667.
EDIT (after timeout): It's pretty important that the values are correct in relation to eachother when impedance correcting, so I'd suggest 4 8 Ohms resistors paralleled for the serial one, and 3 8 Ohms resistors paralleled for the parallel one. Which also means you can use low wattage ones which are usually much higher quality.
- Class D
- MEGABLASTER2010 (2x100w TK2050)
