Memphis st1500
I got this amp last night. I tried to power it on before I layed down.
So I hook my power supply up to the amp sparks flew From the terminals. My power supply was not on. So I measured the DC voltage. Its holding 5 volts at the power terminal. I haven't broke it down,I'm at work now. Any thoughts?
Do they have a lot of Memphis amps in Memphis, TN? Sorry I could not resist.
You know the outputs, drivers boards, and power supply pieces are all potential failure points. Someone possibly thinking this amp is like a Memphis ST1000 may have over loaded it. The 1000 can handle twice the current (Half the ohms) of the 1500.
