I'm looking to build my own projector using a backlightless tft and a MH lighting setup; being a non-expert on the MH bit could anyone kindly confirm whether the following equipment could run harmoniously please?
686934 - HID/K 400w HQI - 400w HID/K Framed 240v Ballast with thermal protection - 4.0a
http://www.dealec.co.uk/acatalog/erc_metal_halide_ballasts_hidk.html
CAP40 Capacitor 40.0mfd 250v Push Wire Capacitor with M8 Stud
http://www.dealec.co.uk/acatalog/Deal_Electrical__DNA_Capacitors_for_Lighting_467.html
640195 Ignitor Fully encapsulated superimposed ignitor in plastic case for 35w, 70w,100w,150w, 250w and 400w single and double ended SON and metal halide lamps
http://www.dealec.co.uk/acatalog/erc_asp_range_ignitors.html
Metal halide Single ended 400watt Eliptical HIE400
A 400 watt ES single ended eliptical metal halide lamp ideal for improved colour redition to run on sodium control gear E27 cap
http://www.bltdirect.co.uk/item952.htm
27mm Edison Screw Lampholder CL27 £5.76
http://www.bltdirect.co.uk/item1029.htm
Thank you for any feedback!
