Midrange enclosure, necessary?
From my 3-way speaker building experiences, I know the enclosure for midrange is absolutely necessary for the closed speaker design. Otherwise, without sealing, the diaphragm of midrange drivers will move while reproducing sound due to the pressure inside the cabinet causing distortion to sound. However, in vented system, will the situation change and the sealing/enclosure for midrange still be necessary?
YSDR, may I ask the reason why? I think the vented system has much less pressure inside the cabinet since the air can exit at the port, so the diaphragm of midrange will no longer move by the pressure. But this is only my assumption.
The air does not exit at the port, instead the mass of air inside the port vibrates to and fro.
The port starts producing some of the sound from around an octave above tuning, and by the tuning frequency all of the bass is produced by the port, with nothing being produced by the woofer directly. The woofer’s travel at this point is minimised to almost nothing at all.
Reactions: GM and presscot
At the port tuning frequency, the internal box pressure is much larger than in a sealed box, moreover there can be not just low freqency pressures but higher frequency content, which can radiate out through the midrange membrane if the mid-driver is not sealed.
The air in the reflex enclosure acts as a spring while the air in the port acts as a mass.
Around the tuning frequency, the to and fro motion of the air mass in the port causes the volume of air in the enclosure to alternately increase and decrease and the pressure in the enclosure to alternately decrease and increase.
So, there is no escaping the fact that an open back midrange driver will be subject to the changing air pressure inside a reflex enclosure.
