Mj15003 And Mj15024
Straight out I have to admit a severely limited knowledge. I'm a user, not a builder. I aquired an old Studiomaster 400C power amp. I can't get details on it anymore.
While I was trying to establish if it is 200W into 4ohms or 8, I noted that one channel uses 4 x MJ15024, The other 4 x MJ15003. What is the difference?
I understand mached pairs but why all the same on each channel. Why not use all the same type?
Lastly both of these device are rated at 250w@ 55V, so why would I need 4 per side?
Confused of london
The MJ15024 is higher voltage rating transistor (250V vs 200V). For the amp power you are describing, the 15003's would probably be ok. The 4 transistors per channel could be two parallelled pairs, or could be 2 series pairs using 4 power supply rails, which keeps heat dissipation low (a few high end amps use this arrangement).
You can get a bit of an idea about power rating by measuring the DC power supply rails: +- 55volts or so would give 200W into 4ohms, whilst around +-67volts would be needed to produce 200W into 8ohms.
Cheers
