I've taken the plunge and opened up my MC252. It's a 250Wpc SS amp that uses Toshiba 2SC2500 power transistors. I am looking to improve the dimensionality of the sound -- it's a little flat. I'm looking for suggestions on changes that may make the most impact.
So far I've made two modifications:
- Changed out input coupling caps from Rubicon electrolytics to Black Gate Standard electrolytics
- Bypassed 27,000µF/100V PS caps with 47µF/160V Black Gate VKs
[/list=1] I'm thinking these changes will make a difference (and improvement, hopefully!). I'm considering some other mods as follows but don't know what will make an appreciable impact.
- There are unbypassed Rubicon YXE 10µF/100V electrolytics decoupling caps on the rails of the amp boards. I'm thinking of replacing them with Black Gates and bypassing them. Polyester, polypropylene, polystyrene? I don't have loads of room so size is a consideration.
- There are two other small-value caps on the rails. One is a 100pF/100V NPO ceramic between the gate and the collector of a driver transistor on each rail -- I believe this is to inhibit HF oscillations. The other is a 0.47µF/100V metalized polyester film (WIMA RN) that appears to be solely for decoupling. I'm thinking I shouldn't fool around with the ceramic but would doing something with the MPF make any difference.
- There is global feedback with a 0.0047µF/5V MFE WIMA cap in it. Worth some action?
- There is also a "current limiter" feedback look applied to the driver input of each rail. The gate of each current limiter transistor is coupled to ground with a 47µF/35V Rubicon electrolytic. This doesn't seem like a high-impact area but I really don't know.
- The bridge rectifier might also be an upgrade opportunity but since I don't know how to characterize what I've got already, any change would be a bigger guess than the others.
[/list=1]
I think that's it. Any thoughts or suggestions would be most appreciated.
KB
Sorry, no schematic
Destroyer, I totally agree that the schematic would make things much more interesting.
Unfortunately, I'm not comfortable posting it.
I was hoping for some general guidance but understand that it may be to difficult.
Cheers.
KB
Cheers.
KB
Non-polar caps for signal coupling
May I recommend that you'll get better sound quality if you use Non-Polar caps for signal coupling. The resulting distortion of polar caps in this position will outweigh the gains in cap upgrade.
There is some disagreement on bypassing Black Gates.
Martin Colloms wrote that "existing selected quality 0.1uF polypropylene de-couplers on the power amp supply lines had to be removed from the circuit as they were found to audibly degrade the performance advantage even of a 47uF 25V standard polarized BG used with no other supplemental high frequency decoupling"
Personally, if I have to bypass, I use 0.1/50v BG NX-H. If higher voltage is required, try 0.01uf/600v film/foil polystyrene caps(if you can find them).
-Chas
So far I've made two modifications...Changed out input coupling caps from Rubicon electrolytics to Black Gate Standard electrolytics
-Chas
