Hi all,
I'm new to Moode, having only set it up a few days ago. Dead impressed.....
Raspberry Pi 3 Model B Rev 1.2 / HiFiberry Digi+ All works perfectly out of the box with the Digi+ - So moved on.
I have a pair of Bluetooth Speakers, they appear to connect., (they announce as such..) but no audio? (JVC XS-D629BM)
(my BT soundbar has the same synptoms)
Other info: Speaker pairs with my phone and work perfectly....
mpd output is changed from local to Bluetooth. I then start to play a radio station, - but no audio...
Is there any other debug I can use/any ideas what's going on ?
Many thanks
Mark
Dec 11 22:36:58 moode systemd[1]: Started Music Player Daemon.
Dec 11 22:37:00 moode upmpdcli[1134]: :3:src/mpdcli.cxx:148::MPDCli::startEventLoop: already started
Dec 11 22:37:32 moode bluealsa[7458]: /usr/bin/bluealsa: D: dbus.c:59: Called: org.bluealsa.Manager1.GetPCMs() on /org/bluealsa
Dec 11 22:37:32 moode bluealsa[7458]: /usr/bin/bluealsa: D: dbus.c:59: Called: org.bluealsa.PCM1.Open() on /org/bluealsa/hci0/dev_17_1A_F3_97_EB_06/a2dpsrc/sink
Dec 11 22:37:33 moode bluetoothd[7449]: /org/bluez/hci0/dev_17_1A_F3_97_EB_06/fd6: fd(32) ready
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:868: New transport: 14 (MTU: R:672 W:716)
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1068: Signal: org.freedesktop.DBus.Properties.PropertiesChanged()
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1104: Signal: PropertiesChanged: org.bluez.MediaTransport1: State
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:750: Starting transport: A2DP Source (SBC)
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: sbc.c:114: SBC setup: 48000 Hz JointStereo allocation=SNR blocks=16 sub-bands=8 bit-pool=51 => 345000 bps
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:1032: Created new thread [ba-a2dp-sbc]: A2DP Source (SBC)
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: a2dp-audio.c:644: Starting IO loop: A2DP Source (SBC)
Dec 11 22:37:33 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:789: PCM resumed: 10
Many thanks
Mark
Helo.
Input / Output
DSP operations
Audio Device
Input / Output
- Source http://stream.antenne.de/chillout/stream/mp3?aw_0_1st.playerid=com
- Encoded at VBR compression
- Decoded to 24 bit, 44.1 kHz, Stereo, 128 kbps
- Output rate 16 bit, 44.1 kHz, Stereo, 1.411 Mbps
- Output mode ALSA Direct (hw)
- Output chain MPD -> Bluetooth stream -> Bluetooth speaker
- Loopback off
DSP operations
- Resample rate
- Selective rate
- Volume type Null (External control)
Audio Device
- Device HiFiBerry Digi(Digi+)
- Mixer name none
- Chip Cirrus Logic WM8804
- Interface I2S
- Formats S16_LE, S24_LE
- Platform Pi-3B 1.2 1GB
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:915: Signal: org.freedesktop.DBus.ObjectManager.InterfacesAdded()
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:998: Adding new Stream End-Point: 17:1A:F3:97:EB:06: SBC
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: dbus.c:59: Called: org.bluez.MediaEndpoint1.SelectConfiguration() on /org/bluez/hci0/A2DP/SBC/Source/2
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: dbus.c:59: Called: org.bluez.MediaEndpoint1.SetConfiguration() on /org/bluez/hci0/A2DP/SBC/Source/2
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: a2dp.c:668: Selected A2DP SBC bit-pool range: [2, 53]
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:291: A2DP Source (SBC) configured for device 17:1A:F3:97:EB:06
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:294: Configuration: channels: 2, sampling: 48000
Dec 13 20:26:16 moode kernel: [187498.156974] input: XS-D629BM (AVRCP) as /devices/virtual/input/input10
Dec 13 20:26:16 moode systemd[1]: Stopping Music Player Daemon...
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1068: Signal: org.freedesktop.DBus.Properties.PropertiesChanged()
Dec 13 20:26:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1104: Signal: PropertiesChanged: org.bluez.MediaTransport1: Volume
Dec 13 20:26:16 moode upmpdcli[1134]: :2:src/mpdcli.cxx:237::MPDCli::eventloop: mpd_run_idle_mask returned 0
Dec 13 20:26:17 moode systemd[1]: mpd.service: Succeeded.
Dec 13 20:26:17 moode systemd[1]: Stopped Music Player Daemon.
Dec 13 20:26:17 moode systemd[1]: mpd.service: Consumed 5min 6.624s CPU time.
Dec 13 20:26:17 moode systemd[1]: Starting Music Player Daemon...
Dec 13 20:26:18 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1068: Signal: org.freedesktop.DBus.Properties.PropertiesChanged()
Dec 13 20:26:18 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1104: Signal: PropertiesChanged: org.bluez.MediaTransport1: Volume
Dec 13 20:26:18 moode mpd[414634]: Ignoring the 'pid_file' setting in systemd mode
Dec 13 20:26:18 moode systemd[1]: Started Music Player Daemon.
Dec 13 20:26:18 moode systemd[1]: Started Bluealsa-aplay.
Dec 13 20:26:18 moode bluealsa[7458]: /usr/bin/bluealsa: D: dbus.c:59: Called: org.bluealsa.Manager1.GetPCMs() on /org/bluealsa
Dec 13 20:26:18 moode bluealsa-aplay[414781]: /usr/bin/bluealsa-aplay: D: aplay.c:805: Starting main loop
Dec 13 20:26:18 moode systemd-udevd[414631]: event0: Process '/usr/sbin/th-cmd --socket /var/run/thd.socket --passfd --udev' failed with exit code 1.
Dec 13 20:26:18 moode upmpdcli[1134]: :3:src/mpdcli.cxx:148::MPDCli::startEventLoop: already started
Dec 13 20:26:21 moode systemd[1]: Stopping NQPTP -- Not Quite PTP...
Dec 13 20:26:21 moode systemd[1]: nqptp.service: Succeeded.
Dec 13 20:26:21 moode systemd[1]: Stopped NQPTP -- Not Quite PTP.
Dec 13 20:26:21 moode systemd[1]: nqptp.service: Consumed 16min 34.942s CPU time.
Dec 13 20:26:22 moode systemd[1]: Started NQPTP -- Not Quite PTP.
Dec 13 20:26:22 moode systemd[1]: Stopping Music Player Daemon...
Dec 13 20:26:22 moode systemd[1]: mpd.service: Succeeded.
Dec 13 20:26:22 moode systemd[1]: Stopped Music Player Daemon.
Dec 13 20:26:22 moode systemd[1]: Starting Music Player Daemon...
Dec 13 20:26:22 moode mpd[414933]: Ignoring the 'pid_file' setting in systemd mode
Dec 13 20:26:23 moode systemd[1]: Started Music Player Daemon.
Dec 13 20:26:23 moode upmpdcli[1134]: :2:src/mpdcli.cxx:237::MPDCli::eventloop: mpd_run_idle_mask returned 0
Dec 13 20:26:25 moode upmpdcli[1134]: :3:src/mpdcli.cxx:148::MPDCli::startEventLoop: already started
Dec 13 20:26:34 moode systemd[1]: Stopping NQPTP -- Not Quite PTP...
Dec 13 20:26:34 moode systemd[1]: nqptp.service: Succeeded.
Dec 13 20:26:34 moode systemd[1]: Stopped NQPTP -- Not Quite PTP.
Dec 13 20:26:34 moode systemd[1]: Started NQPTP -- Not Quite PTP.
Dec 13 20:26:35 moode systemd[1]: Stopping Music Player Daemon...
Dec 13 20:26:35 moode systemd[1]: mpd.service: Succeeded.
Dec 13 20:26:35 moode systemd[1]: Stopped Music Player Daemon.
Dec 13 20:26:35 moode systemd[1]: Starting Music Player Daemon...
Dec 13 20:26:35 moode upmpdcli[1134]: :2:src/mpdcli.cxx:237::MPDCli::eventloop: mpd_run_idle_mask returned 0
Dec 13 20:26:35 moode mpd[415192]: Ignoring the 'pid_file' setting in systemd mode
Dec 13 20:26:35 moode systemd[1]: Started Music Player Daemon.
Dec 13 20:26:37 moode upmpdcli[1134]: :3:src/mpdcli.cxx:148::MPDCli::startEventLoop: already started
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: dbus.c:59: Called: org.bluealsa.Manager1.GetPCMs() on /org/bluealsa
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: dbus.c:59: Called: org.bluealsa.PCM1.Open() on /org/bluealsa/hci0/dev_17_1A_F3_97_EB_06/a2dpsrc/sink
Dec 13 20:26:49 moode bluetoothd[7449]: /org/bluez/hci0/dev_17_1A_F3_97_EB_06/sep1/fd7: fd(33) ready
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:868: New transport: 14 (MTU: R:672 W:716)
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1068: Signal: org.freedesktop.DBus.Properties.PropertiesChanged()
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: bluez.c:1104: Signal: PropertiesChanged: org.bluez.MediaTransport1: State
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:750: Starting transport: A2DP Source (SBC)
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:1032: Created new thread [ba-a2dp-sbc]: A2DP Source (SBC)
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: sbc.c:114: SBC setup: 48000 Hz JointStereo allocation=SNR blocks=16 sub-bands=8 bit-pool=51 => 345000 bps
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: a2dp-audio.c:644: Starting IO loop: A2DP Source (SBC)
Dec 13 20:26:49 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:789: PCM resumed: 10
Dec 13 20:27:16 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:823: PCM dropped: 10
Dec 13 20:27:17 moode bluealsa[7458]: /usr/bin/bluealsa: D: ba-transport.c:789: PCM resumed: 10
Ok, glad its resolved 🙂
I did try a repro earlier with your settings: Volume=Null and ALSA=hw and there were no issues playing to my small ANKER speaker.
