Multiplying DAC used for audio, any experience?
I have great envy to design with the high precision 16bit MDAC LTC1595.
This DAC comes with 2 grades, A, with +/-1LSB max INL or for much cheaper, gradeB +/-2LSB.
I can use the reference input as bi-polar sign bit with adjustable voltage to serve as volume and use only the 15 bits to make the grade B as precise as A.
The only encouraging example I found is the Schiit Audio Yggdrasil
https://www.stereophile.com/content/schiit-audio-yggdrasil-da-processor-measurements
Any DIY exemple?
Any con I should be aware of?
