My DRV134 PCB
Since I completed my design, here for some that are interested, my own version of the DRV134 balanced driver PCB. It has these features: dual channels on one two layer PCB with ground plane, power and signal ground are connected at a star point, optional input resistor and low pass filter, +/- 15V supply with input CRC filter, optional external output sense pins. My first prototype has some errors in the power supply section. The following information has the correction implemented and it is working perfectly. Here a view of the PCB.
I tested the pcb today. Pretty impressive this DRV134 chip. Here my results, both left and right channel measured the same. All measurements were done driving a 1K load. The circuit is stable as a rock, no noise or oscillation.
Gain: 6.4dB
BW (1Khz, Ref 1V): 420Khz (My PCB has a 100R, 220pF cap LPF)
Dist 1Khz, 0dBV: 0.0003%, 10Khz: 0.002%
Dist IMD (1K, 2K): 0.005%
All harmonics are in the noise floor , lower than -90dB, ref 0dBV
DC offset (Input in 50R) (R & L Channel):
V+: 3.5mV, 0.3mV V-: -11.5mV, -13.5mV
Not bad at all.
Are U sure that everything is ok with the schematic from (21st July 2007, 08:31 PM)???
Why Vin's of both channel are connected together via 2x100R & INPUT signals are going to Pin3 (GND) of both DRV134???
One more question:
what is the different between +Vo & +Sense (-Vo & -Sense)???
What is happen when use 'local sense jumper'???
I want to build then amp to drive balanced 'audio in' of camera.
thx, chris sng.pol46@gmail.com
