my own soundboks
hi folks
I will like to make my own kinda soundboks, and i have searched on the internet what subwoofers i should buy. but i cant find any there are over 100 db.(and do i need to have a 100 db subwoofer to make it loud?)
and i dont have much knoweledge about stuff like this. so do you have any recommendations for what subwoofers and dome tweeter i should buy.
thanks
chris🙂
I still need to know which subwoofers and stuff I need to buy
Don't buy any subwoofers - the Boominator doesn't use them. It was built for response to 82Hz (see the thread here).
The Boominator - another stab at the ultimate party machine
That's the clever / compromised core of the design. It doesn't even attempt to go low, because that would ruin everything else that's good about the design.
There are lots of variants out there. Many are covered in that thread. You can clone one or make up your own. If $$ is a factor, you can salvage a lot of the parts - e.g. I run an outdoor system with free (used) car batteries.
That info is in the boominator thread and the soundboks website.
If you DIY, then the portability and cost and finish quality and time spent will all be closely related.
If you used a bicycle trailer or similar, you wouldn't have to worry so much about weight, and could use cheaper parts.
