NAD C370 Integrated
The amp works and looks great, and will come with power cord, manual, original remote, and NAD double box; never modified or repaired!
Asking $300 shipped CONUS
Description: Remote-controlled integrated amplifier with seven line-level inputs (including two tape in/record out); preamp out/main in, and a second preamp out with up to 12dB attenuation; NAD Link; Soft Clipping and Bridging switches. Output power: 120Wpc (20.8dBW), continuous average power into 8 ohms, both channels driven. IHF dynamic headroom into 8 ohms: 3dB. IHF dynamic power (8, 4, 2 ohms): 210W, 340W, 450W. Frequency response: 20Hz-20kHz, ±0.3dB. THD: 0.03%. S/N Ratio (A-weighted, ref. 1W): 94dB. Damping factor (ref. 8 ohm 1kHz): >150. Preamp output impedance: 100 ohms. Headphone output impedance: 220 ohms.
Dimensions: 17 1/8" W by 5 ¼" H by 13 13/16" D. Weight: 26.5 lbs.
