need advice on adding a turntable to existing home audio system
Hello, all. Complete noob here so please bear with me if I'm asking rudimentary questions or if I'm posting this thread in the wrong forum altogether.
I recently acquired an old Panasonic PL 530 turntable. I'd like to hook it up to my current system which includes a JVC RX-D206 receiver and a couple of vintage Kenmore speakers (circa 1970). Here are my challenges in getting this set up working:
1.) Due to the configuration of our living room and speaker/AVR setup, the record player needs to live about 10 feet away. The 2 foot RCA cable coming out of the turntable will need a 10 foot extension cable. This alone I think possible maybe calls for a preamp to boost the signal but I don't really know.
2.) I tested the turntable out on the receiver to make sure it'd definitely putting out a clear phono signal--it is. Although there are a few different available RCA inputs on the receiver, the only input that worked was the RCA input labeled "TV". The volume level output sounded a bit low, TV input is already dedicated for use by the television. Not sure whether or not I need to get a new receiver with a "Phono" RCA input, but if at all possible I'd like to avoid having to buy a new receiver.
Thoughts? Advice? Thanks!
Welcome to diyAudio 🙂 and I love the user name... fascinating little things.
Right then... from what I can see your turntable will use either a magnetic cartridge (the most common type) and these have a low output level or it will use a moving coil cartridge which has an even lower output.
This means that the amplifier or receiver needs to have a dedicated phono input (which is very high gain and also has a special frequency response curve needed for records). I assume your receiver hasn't got this.
Your best option is probably a small stand alone phono stage amplifier and the output of this this would then connect to any spare line level input on the receiver, even via your 10ft lead if needed.
A picture is worth a thousand words!
🙂 those are the ones.
Those more knowledgeable on vinyl matters than I will have a better idea what to recommend.
It would help if you know what cartridge type is fitted, Moving Coil (MC) or Moving Magnet (MM).
Something else to consider is whether you want it self contained and mains powered or whether a separate little mains adapter is more suitable. There are zillions of these things advertised in all the usual places, new and not so new.
Definitely the way to go, yes!
However, I don't understand the distancing of a turntable from its amp.
In my opinion, it's a poor setup, meaning you have to do some walking to use the volume control or other settings, unless of course, the amp has a remote control.
