hi all,
How to make negative voltage using Tube rectfier?
will a diode after rectifier will do? any other method?
thanks.
ynot.
thanks.
ynot.
You need diodes with discreet, not shared, cathodes. If you are building a negative supply using a CT power trafo winding: connect the cathodes to the ends of the trafo, ground the CT, and tie both plates together. Take the negative rail from the connected plates.
ohynot said:hi all,
thanks.
ynot.
6AL5 would be suitable for low current applications for use as a full wave . Dampers or 35Z4 / EY84 etc for higher currents half wave . If you're intending using tube diodes for bias supplies I'd recommend against it though . It's a whole lot easier and saves a heater winding to use snubbed SS diodes if you ask me !
316a
>>It's a whole lot easier and saves a heater winding to use snubbed SS diodes if you ask me !<<
Not only is it easier; in the case of a bias supply, the instant on behavior of SS diodes is BENEFICIAL. A negative voltage on the grid protects against cathode stripping.
The easiest way is to connect the positive output of an ordinary rectifier circuit, (using a tube rectifier) to ground and take the negative voltage from the center tap of the transformer...
BR Hans
