Hello,
I recently bought this card on Aliexpress: https://www.aliexpress.us/item/3256805054463128.html
which should be the most updated version of the card in this thread:
https://www.diyaudio.com/community/threads/cheap-adsp21489-4in-6out-pcm1798-board.339777/
The software that the seller provided me has serious problems, it is not possible to insert the exact values in the Gain and Q parameters because by moving the mouse from the input box or simply passing the mouse arrow over the input box, the value changes randomly, setting maximum or minimum values
I've attached some videos that shows the issue
The software installed is named DP48X control software (version 1.8)
On LCD display is also possible to view the firmware version:
The boad sounds very well and it's possible to connect Amanero card directly, but the control software works very bad, so is impossible to set corret values
Someone bought this card with the same ploblems and solved the issues?
Francesco
Francesco
Thank you so much for your answer. It allowed me to solve the problem. I set the USA area on windows instead of the Italy area
It's incredible that after asking the seller a thousand times how to solve the problem, in six months he was unable to give me the solution
