I'm an unemployed electrical engineer. I've spent most of my career working with audio. I'm trying use my new found free-time to brush up on micro controllers and embedded programming.
Any suggestions or opinions on development packages? PIC/Atmel/WHO?
Any suggestions on texts about sensors and interfacing?
Welcome to the forums!
From a career point of view, any of those would be useful experience I suppose. If you get involved in embedded programming, you could find yourself on rather different chipsets to that.
I am/was an embedded programmer, and I spent a few weeks when I started working on a chip a bit like an old 8-bit 6809, but then it was all 32bit transputer based cores, and eventually linux platforms. Quite different from say a PIC. So learning on a PIC or similar is useful grounding, but don't worry too much about the particular chip you start on.
Being able to use a C (or C++) compiler in an embedded system, and obviously know the language a bit, would be more useful than a particular micro type. There's loads on the web to learn if you're in the dark about C/C++.
Greetings and welcome aboard,
Have a look at this address:
http://www.arduino.cc/
I have not played with it yet. I bought a PIC programming kit from Velleman and programmed a couple of chips.
Have fun.
Serge
Have fun.
Serge
Also check out http://www.mikroe.com/ for a lot of boards and software. A friend got in the big PIC boards and I've been working on coding a big audio switcher project for it.
Very nicely made and the BASIC compliler works fine from my few hours experience. Nice to be playing with uC's again.
