newbie question - best kind of tube amp for full range speakers
Hello All -
I have been spending a bunch of time lurking on these forums, and now I am about to dive in building my own system - I plan on making full range speakers, and I understand that these work well with lower powered tube amps.
Is this the case? Am I right in thinking this?
I understand also that it depends on what kind of music I intend to play - this will be quieter music with lots of dynamic (not compressed...) and field recordings.
Forgive me - there is just so much information on the forums.... What kind of amp works well: Class A? Class A/B? Push-Pull? Single Ended?
Is there a PDF somewhere or specific thread that might answer these questions?
Thanks in advance for any advice!
Kevin
Sorry if it is off topic but is there a reason you are looking at tube amps? Do you want excellent sound quality rivaling or better than many tube amps and even some esteemed class A amps? Try the TPA3116D2. Huge thread in class D forum and folks with tube and class A amps have compared and many agree this amp sounds better. In stock form it is pretty good but add $20 in mods of better caps etc and you have a great amp for $50. Add $100 for input balanced transformers and you have a potentially world class amp. For $20 ea give it a try and see what you think.
If you want something good out of the box, get the SMSL 36A pro (TPA3118D2) for $50. It is boxed with terminals and volume knob with some of the key upgrades already done.
There has been a lot of documented work on the Yuan Jing blue black or "Danzz" board amp. That is one option you can get direct from YJ. It requires at minimum the main power cap upgrade. Lately there is the new Sure TPA3116D2 that has good reports, order direct from Sure. There is also low cost $13 option called the Ybdz or "Weiner" amp from Aliexpress. I use that and really like it.
Also, like I mentioned above, the SMSL 36A pro is very good stock.
SMSL SA-36A PRO 2* 20W TPA3118D2DAP Amp Stereo Digital Amplifier + Power Adapter, by Gemini Doctor:Amazon:Electronics
Many good reports on this one stock. You can upgrade the power caps near the chip with some Panasonic OSCON's SEPF 330uF 25v and it will sound even better.
What, all TD311X amps don't sound the same? 😉
I quite like the Yuan Jing complete kit version I picked up a couple of months back for about $140 landed cost, but sorry, compared to a well executed 6BG4 P/P, such as I heard recently there's some subtlety of "inner detail" and transparency missing with a high resolution FR driver - in this particular case the Mark Audio MAOP7 .
To the OP's question - if serious about pursuing a tube amp, as FR drivers can range quite a bit in net system sensitivity, I'd be inclined to recommend a P/P in the range of 10-15W - something like the Tubelab Simple P/P, for example. I built one with EL84 a few years ago, and it's been sufficient for any of my speaker builds from FR to MTM 2 ways with both series and parallel XO. I believe that George is still in business, but might no longer be selling complete parts kits - i.e. PC boards and schematic/parts lists only.
Designs | Tubelab
I will be building this tube amp in Germany, where I am located right now... so I am trying to find something that will be available here, and not ship from North America.
I am going to be using the Lowther Dx55's I think, and putting them into Nelson Pass's Kleinhorns.... Crazy I know, but they are just so ridiculously big, I have to have them.
Thanks for the input, and any more ideas would be super....
The Yuan Jing and Sure's all ship from China to Germany in 7 days - not expensive shipping.
Since you say "well-executed"... none of the amps from YJ factory will have the necessary mods to make them considered well-executed leading class amps unless they have these mods:
1. Panasonic OSCON SEPF 330uF 25v power supply rail caps x 2 ($1.80 ea)
2. Upgraded TDK ceramic 220nF 50v C0G bootstrap caps x 4 ($2 total)
3. Bootstrap snubber circuit of 330pF 50v caps and 1/4w 10ohm thin film resistors x 4 ($4)
It will sound completely different. The SMSL 36A comes close minus the OSCON's.
To be fair, if you ever get a chance to listen to a TPA3116D2 (note it is T PEE A not T DEE A - which is a different type of amp) with these mods on good speakers, you may change your mind.
There also seemed to be a lack of bass weight with the chip amp. To be fair though, it was tough to hear anything over Cal's PA downstairs.
I'm guessing with those drivers, that system efficiency would be approaching 100dB/w/m? Single ended class A triodes would definitely be on the short list.
jeff
You have a good resource in Germany, tube-town.net. For many designs, a one-stop shop, which is convenient and saves on postage.
I have no connection with tube-town, but I have built many amplifiers, and I know how significant sourcing components can be.
As regards the rest, you can get a TA2024 amp & PSU from eBay for U$20 that will sound pretty good with FRs, as will a whole variety of topologies and technologies, build whatever takes your fancy and fits your budget.
Solid state is normally pure voltage - rising impedance => less output power. Tubes are transformer coupled => more current oriented => rising impedance and power may actually increase depending on configuration.
There are some current oriented solid state amplifiers but I have not found one that I liked. You can mimic by inserting a resistor in line with the speaker but that has other implications.
Class D = RF => bad for your T-cells (immune system)
Cheap entry and a very good (often under-rated) tube is the 6BQ5 (EL84) Single ended. But make sure to have good iron - 95%+ are not up the the task required. Spend a tad more money on getting sensitive drivers = long term less expenditure on replacement output tubes.
(And I have had a lot of tube amps, from flea power to 4 x KT88 120 Watt mono blocks - PP offer not much advantage, if any, over solid state)
PP work best at high power levels (less crossover distortion at high power) e.g. PA work and SE works best at lower output levels (no crossover distortion at all) e.g. home listening environment.
