Hi New guy here. I have a kenwood kac 5020 and kac7020 with all original wiring. Does anyone know if I can just plug in 8 pin din to rca jacks and hook to newer boss stereo unit. Just trying to help out with my sons Jeep
thanks for any help
chris
thanks for any help
chris
As long as the DIN cable is specifically for the Kenwood amp, there shouldn't be a problem (assuming that the amp is in good working order).
Like Perry said Ya you probably could but why would you? That amp is from like 1987 or 88 somewhere in that range. If that amp has been sitting on a shelf unused in all of that time the electrolytic capacitors in the amp are likely toast. For the kind of power that those amps are rated at you can get a brand new one for under a hundred bucks. Those amps weren't all that great back then and they sure haven't gotten any better with age. Just my two cents.Hi New guy here. I have a kenwood kac 5020 and kac7020 with all original wiring. Does anyone know if I can just plug in 8 pin din to rca jacks and hook to newer boss stereo unit. Just trying to help out with my sons Jeep
thanks for any help
chris
One more thing. That BOSS head unit probably has more output then the amps you are trying to hook up to it.
