I need an amplifier with 6 channels. The Emotiva BasX A-700 has 7 channels with 80 watts in 8 ohms. The Dayton Audio APA150 has 2 channels with 75 watts in 4 ohms, bridged 150 watts in 8 ohm (How is that possible? Wouldn't it be 150 watts in 4 ohms?) I could get four of those and use two of them bridged to get more power for the woofers. This is the cheapest option and would be a more appropriate distribution of power to woofers, mids and tweeters. Does anyone have any experience with these amplifiers? Can they even be compared in sound quality?
...75 watts in 4 ohms, bridged 150 watts in 8 ohm (How is that possible? Wouldn't it be 150 watts in 4 ohms?)...
No. Same load, double voltage, makes double current. 2X Voltage times 2X current would make 4X power--- this is what we generally see in Bridge Mode specs.
Bridging 8 Ohms across two outputs makes 4 Ohms on each output, the outputs combine.
As for specific products and sound quality... no idea.
