Opinions on ZROB by Decware?
I recently discovered this thread by Steven where he mentions his goal to design an open baffle full range speaker that’s omnidirectional and has a good low end bass. https://www.decware.com/cgi-bin/yabb22/YaBB.pl?num=1704665765/17
Decware has listed this design as ZROB: https://www.decwareproducts.com/zrob I like the fact that room placement matters less in this design. But I’m not sure if it produces enough bass. Seems easy enough to try and I’m going to build a prototype in a few weeks once my Lii song silver 10 drivers arrive.
Does anyone have opinions on this design?
It's a 'sound' 😉 design with the understanding that for a given baffle size/taper/slope it's driver Qt dependent with room acoustics dominating all, so make it with a fairly wide range of adjustment and fine tune with room tweaking.
Reactions: AbhishekNayak
I think most any OB would like a sub to play with. I use subs on mine.
Steve Decker is an audio god, read his white papers.
I will, on Steve's advice add a Dayton Audio AMTPRO-4 Air Motion Transformer to my setup.
This is the driver used on the ZROB design.
