I am running Orcad's PSpice AD Student version 9.1 to simulate some amps for uni/fun.
But I open my .CIR file in this and edit, then click 'run' to simulate, this will run a simulation, however my problem is this...
If I open the 'view simulation results' graphs window then add a trace I see it fine, when I go back to the .CIR , make some changes and then hit 'run', I have to open the graph window and add the trace again
This may seem trivial but it used to just update the graph and not 'get rid' of it. So I edit simulation settings and I see there is a tick box just for this problem but it is greyed out
Any one has any ideas?
Also, is there any way of putting in a inductors Q factor, or do i have to keep putting in a resistor.
any help will be great...
TED
TED
