Parallel output tubes
Joined 2021
Hello!
I have noticed some amplifiers using parallel output tubes include one coupling capacitor per control grid (C1,C2 below), while others just connect the grid stoppers together then just one capacitor (C3) to the driver plate.
Is there any advantage of using separate caps?
Regards,
Jose
Component count isn't the important point here, me thinks 😉. For self bias I'd chose individual cathode resistors and capacitors for each tube. Anyway you're right, individual coupling caps aren't necessary then.
Best regards!
Agree. Individual cathode resistors and caps is a must, in my opinion, when paralleling output tubes and using self-bias. Easier to match the tubes.
When using cathode bias, only one coupling cap from the driver is needed. When using fixed bias, each needs it's own coupling cap.
Also when using cathode bias, each tube should have it's own cathode resistor (or CCS) and bypass cap though.
Reactions: jcalvarez
The schematics have something missing:
There needs to be a grid leak resistor, one end to the grid stopper, and one end to ground;
Or in the case of fixed bias, one end to the grid stopper, and the other end to the fixed bias voltage.
Since grids have maximum grid leak resistance ratings, the schematic with only one coupling cap - requires a resistor that is 1/2 of the maximum rated value (it has to return 2 grids).
Boats are meant to be floated.
Grids are not meant to be floated.
I apologise for my laziness, I just put the diagram quickly, did not include leak or bias resistors.
