Up for collection only and from Milton Keynes is my Aleph 3 clone .
In excellent cosmetic condition and perfect working order.
I’m looking for what I paid for it which was £650 ( for established members )
I may also consider a swap for a quality preamp but it must have remote control.
It has a ding on the very back right hand cooling fin ( not me )
Please message me if interested
It’s a beast of an amp so you may struggle to fit it in a Hifi rack .
30w class A
Built by Joe Henry
Dimensions
50cm Wide
40cm Deep
22cm High
Speaker protection
Dual toroidal transformers
Dual 50 amp bridge rectifiers
Dual power supplies
160,000uf Elna capacitors
Double-sided thick gilded PCB boards
Power Soft start circuit
Blue LED on/off switch
Input differential Transistors using the new US FU9210
DC blocker
Precise matching mosfets
Supply rail fusing
XLR balanced inputs
RCA inputs
Audio grade binding posts
SPECIFICATIONS
Gain 20 dB
Freq. Response - 0.5 dB at 2 Hz, 100 KHz
Power Output 30 watts/ch 8 ohms
60 watts/ch 4 ohms
60 watts/ch 2 ohms
Maximum Output 23 volts, 8 amps
Distortion (1KHz) 0.2% @ 30 watts, 8 ohms
1% @ 60 watts, 4 ohms
1% @ 60 watts, 2 ohms
Input Impedance 23 Kohm
Damping factor 100
Crosstalk > -80 dB 20-20 KHz
30w class A
Built by Joe Henry
Dimensions
50cm Wide
40cm Deep
22cm High
Speaker protection
Dual power supplies
DC blocker
Supply rail fusing
XLR balanced inputs
RCA inputs
SPECIFICATIONS
Gain 20 dB
60 watts/ch 4 ohms
60 watts/ch 2 ohms
Damping factor 100
