Hello
Difficult to choose between him X 1000.5 and Xa 200.5, somebody of us would have been lucky to listen to these two amplifiers I look for transparency, heat, sweetness and dynamics on wilsons 2s maxx
you Nelson which indeed his, what amplifier which both would put you with Wilsons
Cordially
robin410
Cordially
robin410
Salut Robin,
I had the chance to listen to both amps with Wadia digital frontend, TW Raven, Graham Phantom and Koetsu Rosewood on X ONO and a X0.2 preamp as analogue frontend.
Both poweramps were setup with either B&W N800D (far from being my favorites), Audio Physics Medea (much more like it) and Wilson Alexandria.
Personally I would go for the XA200.5! On any of those speakers the XA200.5 had a slight advantage, musically more involving...my own 2c...🙄
But on the other hand, we are talking really big rollers here...
hello mach
I think as you ,the Xa 200.5 really has to have a good sound, but in front of this level , i always ask the question: whom to choose
i like very much the class A , in spite of their weak return
thank you
friendly
robin😉
thank you
friendly
robin😉
Hey Robin,
the XA200.5 is a Class A product as well. It will not work throughout all powerrequirements in full Class A and revert to A/B but this is not noticiable.
For this, I highly recomend the following article: Leaving Class A | Pass Laboratories
In my experience, the label "pure Class A" will haunt your mind and you expect a more perfect performance out of this iso an amp reverting to Class A/B at some stage.
And lets face it, at certain volume levels, you will have much more distortion from your speakers (yes even the Wilsons! @ 90dB+) and your listening environment, than any good Class A/B amplifier will ever produce.
