pioneer deh-7700mp and gm-5100t amp
head unit deh-7700mp 3 pre outs i believe thats what there called also have gm-5100t amp and 10 inch pioneer sub. rookie to this but good with electrical, how can i get all speakers connected to amp, have sub output on head unit will it work without hooking to amp or do i need an amp to power the sub, can the rca outputs be cut at one end wires stripped and hooked to speakers or is there some part i need to hook the rca plug to speakers. do i need to use the preout to run the speakers if i want to hook to amp., i hope i've explained this ok. oh ya i've tried hooking up the sub to the deck without the amp and i can't get it to work thats why i asked do i need an amp to powere the sub
thanks
You need the amp to power the subwoofer. If your intending to hook "all" meaning 4 full range speakers in the car to the amp also it is pretty impratical. You need to use a passive crossover which at a proper crossover point is basically a waste of money. Hook them up to the deck for now and use a amp later. Your
RCA's are line level and are never intended to power speakers themselves and doing so will likely damage your amp.
Go here for basic knowledge
Basic car audio.
