I was givin a cd player to look at and as soon as I hooked up the power wires the ic amp started smoking.
Can I take out the IC chip and still use the rca outs?
You'll lose remote turn-on.
You can connect the remote turn-on for the amp to the ignition wire behind the head unit. If you don't want to tap into it, connect a jumper between the b.rem and acc terminals on the circuit board at the point where the power/ground plug enters the circuit board.
