Pioneer PL-5 Speed Issues
I recently bought a Pioneer PL-5. I got it hooked up and found that it didn't play speeds properly. I found a couple YouTube videos that addressed this problem. I took the turntable apart. Cleaned it, oiled the motor bearing, cleaned all the switches and pots with contact cleaner so and so forth.
I put everything back together and tried it out. I was able to adjust the 33rpm with the adjustment pot, but I couldn't get the 45prm to adjust at all and runs too slow. The speeds will would skip fast for a second and the back to normal and there is an audible noise as well when it happens.
I have a feeling that I will need to recap the circuit board, But I wanted to see if anyone else had any other ideas before I start doing that. Is it even worth the trouble recapping it? This isn't my only turntable and fortunately I didn't pay much for it.
Any input would be great!
