Playstation PS2 PS3 Multi AV Connector?
As far as I know, the Multi-Out port connector is Sony's own proprietary connector design. I searched far and wide and never found a source for this connector. If anything, you might want to scavenge a connector from an AV cable and solder your own wire to the connector. This would require cutting open the connector enclosure to access the individual connectors. I am not sure this is worth the effort though. It might be easier to route the Playstation's outputs to RCA connectors.
The Namco GunCon controllers for PS1 came with an attachment that went into the AV port, the attachment has a male and female connector on it along with a composite connector. Without this attachment the laser gun would not function. Unfortunately these are not easy to get hold of.
