Plywood VS MDF for speaker construction
MDF is terrible to work with. BB is a Joy to work with. Planet10 has convinced me that BB is a great choice, and I decided that there's no need to look at anything else.. With good bracing box radiation is not a big issue. Not very audible!
The bad news. Just purchased 2 sheets of 1/2 BB at $98ca per sheet!
Reactions: fishball79
Yeah the price of a lot of building materials has gone bananas! I too have a Baltic birch build in my future.
Solid? or more stabile?...or more rigid?.....Depending on the wood, it might be more "solid" certainly an OAK board will be more solid than a Pine board....But plywood, because the plies run in opposite directions is way more stabile......And solid wood might be more rigid against the grain, but with the grain it is very weak. We've all seen karate folks break boards.....usually with the grain. ....I still believe a multi layer, no voids, properly glued plywood is the best....And Baltic Birch is about as close as you are going to get to perfect plywood.
Reactions: Speedysteve7
It appears i have already made an appearance.
Solid wood can be made into a nice enclosure but the builder needs to know what they are doing.
Here, both Bernie and Scott have built a number of very nice solid wood enclosures. These in Yew.
The biggest issue, i understand, is humidity changing significantly.
But safeest is quality plywood, if you want to step up, stranded/fossilized bamboo plywood.
dave
So Marine ply would be best then?
I've used lots of marine ply as back in the 80s I was building small boats. Unless it has gotten better, the surface quality was never as good as Baltic Birch. Marine ply was not a finished good, but used mostly in structure and usually covered with fiberglass or some other covering. Baltic Birch does not have waterproof glue, but much nicer surface finish and sometimes , more, thinner layers.
BB plywood is made of hard/dense birch plies the whole way through. Because the plies are thin there is lots of glue in there as well, adding to the density and stiffness. There is also "Apple-Ply" which is same thing with hard maple and made in the US, I believe. These materials are better not just because they are hard and stiff, but because they have no voids and hold screws very well, even in the "end grain." I read that you can even tap holes in BB and use a machine screw.
Marine ply is, as far as I know, simply regular construction plywood with no voids and waterproof glue. It's usually made with lighter softer wood, like Meranti or fir. I've seen it with many thin plies or fewer thicker ones.
"Hardwood" plywood consists of a paper-thin hardwood veneer glued over much softer and thicker plies. It's a cosmetic product.
Any of these are better than MDF. But there is also a product called MDO, medium density overlay, which is veneers of MDF glued over solid wood plies. Might be a good compromise if the surface finish is a priority.
I only wish I could get nice plyboard, construction grade is about all you can get around here 😢
Im sure its available in the biggest major cities but for us regional folk here in Australia its near impossible to obtain
There is a plywood grade called shuttering grade, used for forms when pouring concrete, it has to withstand the curing before being removed.
I know somebody who uses a lot of plywood, he sourced it from Russia, but now lead times are long, price is pay up front, and delivery is erratic. He shifted to Eastern European.
And as Adason says, foam board...
There is also something called wood polymer composite, dried saw dust and plastic bound together, used a lot for fences and decking.
Should work, provided you get it, and hopefully some people have already tried it. It is outdoor grade, acoustic properties unknown.
