Hi everyone,
Can anyone make a recommendation for a potentiometer for one of those little white Sanwu TPA3110 amps? What resistance would be best?
Thanks!
Sent from my Nexus 5X using Tapatalk
Thanks!
For volume control one needs a logarithmic potentiometer, not a linear one. When using a linear one operation is frustrating. What value is depending on what the gain factor is of your board. TPA chips have varying impedance. They are highest impedance when 20 dB mode is chosen. Please check. datasheet. They are 60 kOhm in 20 dB mode and only 9 kOhm in 36 dB mode ( in which they hiss and are way too sensitive as a bonus).
In 20 dB mode a 50 kOhm stereo logarithmic potentiometer will work OK (if you use 2 channels). There are cheap stepped attenuators on Ebay that work fine and have better properties than potentiometers.
I have 2 amps, the Sure mono TPA3110, and the Sanwu. The Sure is 26db gain, but I can't seem to find that for the Sanwu.For volume control one needs a logarithmic potentiometer, not a linear one. When using a linear one operation is frustrating. What value is depending on what the gain factor is of your board. TPA chips have varying impedance. They are highest impedance when 20 dB mode is chosen. Please check. datasheet. They are 60 kOhm in 20 dB mode and only 9 kOhm in 36 dB mode ( in which they hiss and are way too sensitive as a bonus).
I need a pot with a rotary switch, so I'm looking at either a CTS or a Bourns pro audio, I'm just unsure of the resistance. I did know that I need an audio/log taper.
It's the AA-AB31521. On e bay look for item number 141535600436.Hi muddy, do you have filterless Sure mono?
For future reference, in case anyone stumbles across this wondering about either of these amps, the Sanwu sounded much better than the Sure. It's much more clear.
I've always been partial to a good 10k pot. Never had a problem driving one with any modern source.
Yeah that's what I wound up getting. A Bourn's audio with a built in switch. Works great.I've always been partial to a good 10k pot. Never had a problem driving one with any modern source.
- Class D
- Potentiometer for TPA3110 AMP
