U1 and U3 should be matched.
U2 and U4 should be matched.
J113 and the other should be close match, U5 and U6.
Should be ~2 mA each.
Q1:
is it better if you use a other JFET for CCS instead of J113?
other members mentioned at different threads that J113 has a bigger current noise .
Q2:
does a snubber with 220pF and 47R at the power MOSFETs reduce something? connected between Drain to gate.
at the VSQA amp thread its an idea to avoide oscillation - i did this on a real FX8 amp with LatFET and it give me better sonical improvement at higher frequencies, e.g. flute, singers, high hats...etc....feels more open.
kr
chris
Q2:
kr
chris
Seems very sensitive to set up bias, maybe some resistors on the source pins of IRFP's might be desirable?
- Poweramp 10 Watt IRFP240/9240 Symmetric Class A
