Prasi CRC Ideal rectifier psus, part populated
Joined 2018
Selling these on as I have gone a different direction and now using Prasi Capmx set up.
I intended to run these as dual mono so one of these boards per channel of chip amp.
Has Roederstien 6800uF 50v caps, faston tabs, and the Mosfets soldered in.
High quality boards as you know from Prasi.
Asking £20 each or £30 if you want the pair. Postage anywhere at cost. Probably less than £5 UK and a little more into Europe. ROW i would have to quote.
