Pros and cons Pioneer PD-8500 and Marantz CD-54
To avoid over inflated opinions and coming to help on buy for others and myself out of curiosity I am first presenting my case and going down to an personal opinion.
Out of CD Players first CD Players that were better were the Pioneer PD-8700 very warm and most lovely open to sound stage and one small Philipscan not remember but still sounding detailed forward but not so large to life.
also had a sony CDP-XB920QS that was precise, not so forward all sounds almost on one shelve but too bright.
Now I have Pioneer PD-8500 that I knew since bought new in 1993 than passed to another friend both tidy users with high regards of using the tech and than me being the 3rd owner of the CDP.
Now the hard part comes:
A friend of mine bought a Marantz CD-54 all ok nice looking Bladerunner stuff tech that you would expect to see in the pelicula. the owner presented it as the best CD Player that most but not even a 3000usd CDP would step over with fancy dacs and electronics.
As well when the guy saw my CDP Pioneer PD-8500 Reference 2 x PCM63P-J 8kg sayd it is mostly a piece of Chinese not upto the nose or nearly of the CD-54.
I can not belive such a thing until now having at hand and tested over 50CDP.
Not raise a plaque on both components I am asking could one of these be more in your blood or should the pioneer be put in the book of electronic components history as in his own words a flimsy piece of electronic product.
I have put head to head the Pioneer with Sony CDP-101 and the Pioneer smashed it. music with passages as glass that brocke made you feel the broken glass around you and music impressions and instrumentation came directly to you to feel it as a fisycal thing all being clear image an product.
The Sony sounded rounded and a little bit muffled.
The marantz did not get in my set for comparison but now again Pioneer against Marantz what race and speccies are they?
Pioneer PD-8500
Specifications
Disc format: CD
Digital converter: 2 x PCM63P-J
CD Mechanism: PWY1011
Frequency response: 2Hz to 20kHz
Dynamic range: 98dB
Signal to Noise Ratio: 112dB
Channel separation: 108dB
Total harmonic distortion: 0.0019%
Line output: 2V
Digital outputs: coaxial, optical
Dimensions: 420 x 326 x 132mm
Weight: 8kg
Marantz CD-54
Specifications
Disc format: CD
Digital converter: TDA1540D, 14-bit linear
CD Mechanism: CDM-1
Frequency response: 3Hz to 20kHz
Dynamic range: 90dB
Signal to Noise Ratio: 90dB
Total harmonic distortion: 0.003%
Line output: 2V
Dimensions: 320 x 90 x 291mm
Weight: 6.5kg
Year: 1984
