~$50 high Qts, high Qms - might be fun in an open baffle system (PRV's 10FR300 is only about $9 more)
PRV Audio 8FR250 8" Full-Range Speaker
its more suited to OB than the new SB FR8 with regards to LF behavior
>Typical junk 2-4khz though.
Couldnt that be pretty easily ironed out using DSP filters? I thought all such FR drivers had some "specific character" that could use a bit of tweaking. Some just get used to it and like the sound of a particular driver as-is.
Regarding achieving a flat frequency response I'd believe that starting out with a pretty good design initially, then adding the minimal frequency corrections is going to be similar to amplifier designs and amount of global feedback.
I'd work on that 2-4k region using DSP and - with my ears - leave the 10 - 20K levels untouched.
