Punch 45 Schematic
Looking for schematic for a Punch 45 , it is the model after the original Punch, second generation I would call it. It is not the HD version. This amp I purchased in 1991 has been flawless till a few years ago. Left channel developed a buzz only when signal is connected. I had set it aside a number of years ago and bought a newer Punch to replace it. Well after reading and becoming a member here I have learned so much in a short amount of time. I dug it out , pulled it apart and found a cracked solder joint. Its now been running for 3 hours on the bench working perfect. I would like to have a schematic should any other issues arise in the future. Thanks in advance and happy listening. I will add a few pics this amp is nearly 100% new like condition, still has original sticker on the front.
Collin Stuart
