This is one of the few made in England versions.
Serviced by Quad in October ( invoice to prove )
Original owners manual
Original box ( not original foam packaging)
In excellent condition and perfect working order.
£550 + shipping at your expense and risk.
Specifications
Power output: 140 watts per channel into 8Ω (stereo)
Frequency response: 13Hz to 40kHz
Total harmonic distortion: 0.01%
Input sensitivity: 0.775V
Signal to noise ratio: 108dB
Speaker load impedance: 4Ω (minimum)
Dimensions: 321 x 140 x 240mm
Weight: 12kg
Specifications
Weight: 12kg
