Question about common mode choke
RS Components | Electronic and Electrical Components ... s/4890425/
Am I right in thinking that a common mode choke such as this can be wired in two ways?
The normal way (according to the datasheet) is "both dots on the left". Used for noise rejection, and to prevent noise from the load being passed back into the PSU. Happy to be corrected. I believe in such mode the choke provides almost no inductance and therefore almost useless for power smoothing in a filament supply.
My question is, can such a choke be wired "top dot left, bottom dot right" so that it DOES provide inductance and in conjunction with a cap would provide some smoothing and ripple reduction?
CM chokes will saturate at very low currents when not wired so currents go in each direction into and out of the dots. Also the inductance is much lower than specified if used single ended. Might as well use a ferrite bead.
The rated current is only if wired as a CM choke. They do provide high impedance to CM signals/noise but none to differential currents.
U might get away with some useful filtering if u wire the two windings in parallel. Both dots to same end. U will get 1/4 inductance but it might handle a few tens of mA.
Edit: the filtering is obviously only significant at high frequency.
