Raising bias on Marantz SR4200 AV Receiver
Joined 2004
I have had success with new op amps (OPA1642), and it's sounding better as a DAC and preamp.
As this receiver uses the power amp section to drive headphones, I was hoping to raise the bias to help it sound better. How is the bias set, and how do I raise it? I'm guessing it's to do with the ratio of R611, R619, and R691? If so, maybe I can insert a pot here?
Any other low-hanging fruit to knock down in the power amp section while I'm in there? (C501 has already been swapped for an Elna Silmic...)
Thanks in advance!
Andersonix
Thanks, jaycee! Decrease R611 only? Nothing with R616, R691? Maybe I will put a 1k Ohm pot there...
Every amp I've ever tried it on sounded better with more bias. I'll keep a close eye on the temp rise. I don't use the power amp section, so it's just for headphones.
